Jump to content
Наушники Grado GS-1000i c кабелем Black Dragon
52,000.00 RUB
  • Price 52,000.00 RUB
0 Offers
Наушники Grado GS-1000i c кабелем Black Dragon,коннектор Furutech FP-704(G).Это фабричная опция, а не твик.
Куплены в США за 1260$.  Совершенно новые.Прошли только частичный прогрев-примерно 100 часов.
Black Dragon V2 Details
The Black Dragon uses 4 x 21.5AWG Teflon insulated stranded conductors using pure single crystallized UP-OCC pure copper with 7N purity 99.99998%. This means more music, clarity and sound quality gets to your ears as purity in cable construction, cable design and quality of materials make a noticeable difference in the sound quality of your headphones.
Each conductor is made up of a special varying size stranding geometry. The copper stranding is mixed with Kevlar stranding to reinforce the conductor. Making it stronger overall and less prone to failure due to the harsh constant flexing a headphone cable receives. The conductors are then surrounded by cotton and then a layer of Teflon tape.
The new version is now also shielded and placed in a polyethylene jacket for further protection.
The wire is soldered to the connector with Cardas silver solder. The default 1/4" Plug is the Furutech FP-704(G). The default 1/8" plug is a Neutrik NYS231B. And the default XLR is the Black Neutrik NC3. The wire is then covered in 2 layers of Techflex braid.
The cable is extremely smooth sounding with great low end and wonderful voicing. And will remove the veil all Sennheiser headphones just like the Silver Dragon. Most stock headphone cables are made of poor ultra thin conductors that work as a bottle neck for the sound.
If you listen to any type of music then this is the cable will suit your needs. It is a little more rounded than the Blue Dragon. Fuller Sound and more bottom end weight.
Other adverts from портативное-аудио
