ЦАП M2Tech Young MkIII - Sources - SoundEX - Клуб любителей хорошего звука Jump to content
76,000.00 RUB
  • Price 76,000.00 RUB
0 Offers
ЦАп практически новый , к нему подарочный бонус (линейный блок питания ) В ЦАПе используется чип Burr-Brown PCM1795. - Inputs: analog single-ended (RCA), SPDIF (RCA), AESEBU (XLR), Optical (Toslink), USB 2.0 high speed, Wireless
- Outputs: analog balanced (XLR), trigger (jack 3.5mm)
- Sample frequencies: PCM 44.1kHz to 384kHz
- DoP 64X to 128X
- Native DSD 64x to 256x
- PCM resolution: 16 bits to 32 bits
- Signal-to-Noise Ratio: 118dBA (single-ended) 120dBA (balanced)
- THD+N: 0.0008% @ 5Vrms out balanced
- Output Voltage: 2.5Vrms or 5Vrms (single-ended), 5Vrms or 10Vrms (balanced), 12VDC (trigger)
- Output impedance: 100 Ohms (single-ended) 200 Ohms (balanced)
- Input impedance: 47 kOhms (analog) 75 Ohms (SPDIF) 110 Ohms (AESEBU)
- Supply voltage: 15VDC
- Power Consumption: 4W (operational), 0.23W (standby)
- Size: 200x200x50mm (wxdxh)
- Weight: net 2kg (including ancillaries), gross 2.5kg
Тверь - Russian Federation
Other adverts from Валерий К .
Other adverts from источники
