Акустика за 12 000$ выбираем. Sonus Faber, Magico, Marten, Veriity, Dynaudio, Spendor... - Страница 41 - Акустические системы - SoundEX - Клуб любителей хорошего звука Перейти к публикации
Зацепила:        diva04.jpg        diva03.jpg        The new Callas Diva model is a three-way floorstanding speaker that replaces the previous model with the same name. It has been completely redesigned. The performance of the new Callas Diva is at the level of the Grand Callas model but with a significant reduction in volume to be use in smaller room. The low range, reflex loaded design, uses one 8 inch "long-throw" woofer, while the mid-high range is reproduced by a 7" annealed polypropylene midrange and by the 1" Scanspeak 9700 tweeter. The diffuser is complemented by the back radiation system that uses two Tweeters configured as a "natural dipole". It is obvious the effort to keep all the best features of the Grand Callas 2014 model to offer a complete, high-quality sound , a flexible system that is easily adaptable to the environment, all within an aesthetically pleasing cabinet, and also with a particularly good value for money .The back radiation system uses two tweeters connected as a natural dipole. The performance of dipole is virtually indistinguishable from the triplet used on previous Grand Callas. The back radiation feeds the reflected field without interfering with the direct sound , while preserving the accuracy of the transient response. The back radiation balance the power response and increases the "Brilliance" which is a quality related to the perception of sound details. Improving the perception of detail means improving the perception of “space". The front panel of the cabinet of the new Callas Diva was shaped as to make possible a “close listening” position (with the listener even around a meter and a half from the loudspeakers) and makes this speaker very flexible and adaptable to various situations (for example, areas where the reverberation time is not particularly low). The other feature that contributes to the flexibility is the ability to modify the response of the low frequencies ( closing the reflex port ). The Callas Diva 2016 produces a sound stage that expands in three dimensions with an excellent impulse response and power , dynamics and extension at low frequencies worthy of the best in its class .        Size:
116 x 37 x 53,5 cm (HxLxP)
Weight:
65 Kg each including metal base
System:
Reflex, floor-standing with rear firing radiation system (dypole)
Finisches:
Lacquered Mahogany / Lacquered Walnut
Front driver:
1 x 8” long-throw woofers, 1 x 7” midrange with polypropylene re-cooked cone and phase plug.
Frequency response:
30 -25000 Hz
Cross-over:
12 dB/ott. For woofers
                12 dB/ott for midrange
                12 dB/ott for the front tweeter
                12 dB/ott for the rear tweeters
                frequencies 200 e 2000 Hz ( aprox )
Cross-over frequency:
0000 Hz
Maximum Power:
240 Watt (without clipping)
Recommended Amplifier:
test amplificatore
Sensitivity
90 dB/2.83 Volt/1 meter
Nominal Impedance:
4 ohm (Z min >3.2 ohm)
Position on environment:
at least 10 cm from the rear wall
7 часов назад, Равшанбек сказал:
Выглядят зачетно.
В 11.01.2020 в 13:29, SpaceMonkey сказал:
Процесс сборки вызывает вопросы (а у производителя есть ответы :) ):
Судя по видео нарезку плит, сборку, наложение шпона, покраску, сборку НЧ динамика, сборку АС и упаковку делает один человек.
  • 1 месяц спустя...
В 11.01.2020 в 16:24, Dmitry сказал:
всё своё , ручная сборка "с душой"  - красивый процесс.  Респект
Познавательное видео, с интересом посмотрел.  Фильтры, динамики. Вот только когда собирали корпус, вспомнилась почта и упаковка посылки.
  • 2 месяца спустя...
Franco Serblin Accordo Essence будут стоить £12 998. За эти деньги покупатель получит трехполосную фазоинверсную конструкцию с 29 мм твитером Ragnar Lian, 150 мм СЧ-драйвер и 180 мм басовик (оба с диффузорами из специального материала с использованием микросфер). АЧХ Franco Serblin Accordo Essence
находится в пределах от 35 до 22 000 Гц, чувствительность составляет 88 дБ, сопротивление - 4 Ома. Колонки могут работать с усилением от 20 Вт. Каждая АС весит 60 кг.        Интересное предложение :Cool:
  • 4 недели спустя...
Шёл который год выбора акустики и усилителя..... :)
17 минут назад, SENATOR сказал:
- 20 июня, 2019 - Так который год? Акустика выбрана о чем выше написано, усилитель тоже. :Cool:
Тогда ждем получения, инсталляции и радостных ощущений?)
За $12000 я искал бы на вторичном рынке (но это я):
Zingali Twenty Evo 1.2
В 08.06.2020 в 01:49, Равшанбек сказал:
Мне очень Серблин нравятся
13 минут назад, Kostya Kostin сказал:
Чем нравятся?
Только что, Panamera сказал:
Чем нравятся?
Внешне красивы
2 минуты назад, Kostya Kostin сказал:
Внешне красивы
Гламурненько выглядят, итальянцы.
8 часов назад, Саш Бар сказал:
Интересно кроме вокала они ещё что могут?
Они все могут
1 час назад, Саш Бар сказал:
Они все могут
смелое заявление :rolleyes:
Я хорошо знаю Зингали.
2 минуты назад, Саш Бар сказал:
Честно, слушал один раз, давно запомнил что певучии :Cool:
3 часа назад, Равшанбек сказал:
Могут общественные пространства озвучивать;)
Zingali Acoustics
Саш Бар не одобряет дизайн новых Quantum Array, а вам как
Все динамики для Zingali делает SICA, все кастомные конешно.
Не то, что не одобряю, кто я такой, чтобы одобрять или нет, но на фото они похожи на АС из "Звездных войн". Мне больше нравится натуральное дерево.
Эти Quantum Array я не слышал, они совсем новые, но их хвалят, а Twenty Evo 1.2 меня удивили, они явно быстрее старых линеек,  универсальнее, очень живые. У них только нет сверхнизкого баса, который бы кишки выворачивал. Вообще о Zingali у многих странное мнение, мне кажется, что многие судят просто по внешнему виду.  Люди любят большие брутальные, тяжеловесные АС, не понимая, какое значение может сыграть хорошо настроенный рупор и как легко он может снести башку. Какие драйверы сейчас там я не знаю, но мне  очень нравятся компрессор-драйверы, которые использовались ими в нулевых.
41 минуту назад, Саш Бар сказал:
В смысле как (теоретический) элемент вашего интерьера вам они не нравятся. Имо всем можно что угодно одобрять или не в виде мне нра\мне не нра. Мне почти нравится дизайн Квантумов, а деревянные унитазы не.
Как Квантумы на ух - интересно; немногое написанное и внешний вид этому не противоречат. И выпуск РА тоже.
Про всю кастомную сику - из какого-то их прошлогоднего ролика.
