Georgiy Опубликовано: 15 января 2015 Поделиться Опубликовано: 15 января 2015 У Снапперов после замены восьмерки электрогармониксов EL34 на бас стал более очерченный, собранный, осязаемый, его стало больше и он стал гораздо интереснее. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 16 января 2015 Поделиться Опубликовано: 16 января 2015 По поводу замены драйвера GE-6414 нашел вот такую инфу на ебэй которая указывает на взаимозаменяемость GE 6414/E180CC/5965/12AT7 http://www.ebay.com/itm/Matched-Pair-GE-6414-E180CC-5965-12AT7-tubes-Triple-Mica-1950s-Manley-VTL-/201147263762 Item Description Matched Pair GE 6414/E180CC/5965/12AT7 tubes Triple Mica 1950-'s and 1960's date codes! Good tubes - good sound - great price - Buy 2 pairs for matched Quad! This listing is for one matched pair of Raytheon 6414 audio preamp tubes which can be used in place of 12AT7 tubes with the following benefits: 1. Long heater life with MTBF estimated at 10,000 hours 2. Very low noise floor with about same gain as 12AT7 3. Excellent sound stage due to longer plates and excellent construction with triple mica and blate plates 4. Superbly matched as all tubes have the same or very close date codes typically in the late 1950's early 1960's (some may be different codes, but all matched for transconductance and noise figure) on them from same manufacturing batch - great for multi channel preamp drivers and phase inverters. I matched these on my MaxiPre audio preamp tube matcher and they matched within 5% of each other with very low noise floors of -85db (most excellent 12AT7 tubes have -80db noise floor so these are much much better - great for phono stages). Since all these tubes are from close manufacturing batchs, you can order two pair and I will ship a matched quad, three pair for a matched sextet, etc. I have 28 tubes available in total or quantity 14 pairs Also check our other listing that use these tubes with others you may need to retube your amp. We put together sets based upon feedback from over 14,000 customers who have tried just about every brand and combination possible. КАКИЕ РИСКИ? Можно пробовать втыкать вместо драйвера 6414 указанные аналоги? Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 30 марта 2015 Поделиться Опубликовано: 30 марта 2015 Что взять в запас на вход 50-х моноблоков, SIEMENS ECC801S NOS или BRIMAR 13D9/Industrial E81CC NOS ? Вместо драйверной 6414 поставил Сильванию 12BH7A, прочитал о совместимости в документации Manley на сайте Стереоправды. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Cергей Лебедев Опубликовано: 30 марта 2015 Поделиться Опубликовано: 30 марта 2015 Все взять 1 Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 20 сентября 2015 Поделиться Опубликовано: 20 сентября 2015 Тема драйверной лампы к 50-м моноблокам и Снапперам не закрыта, т.к. эта лампа "ведает" коэффициентом усиления, купил несколько вариантов, в т.ч. Сильвания, GE и RCA. 1 Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 20 сентября 2015 Поделиться Опубликовано: 20 сентября 2015 Ждём результатов! Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 2 октября 2015 Поделиться Опубликовано: 2 октября 2015 Пора уже поведать о результатах замены доайверной лампочки! Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 2 октября 2015 Поделиться Опубликовано: 2 октября 2015 Через неделю не раньше, еще не все лампы подъехали, будут через пару дней. Буду пробовать на полтинниках и на Снапперах , они там разные, 12BH7A и 5687. Еще взял квартет Сименсов EL-34 старых NOS, надо еще где то квартет таких же искать по разумной цене, говорят очень басовитые, надо попробовать на Снапперах. Тридцать четверки от комплектации Manley 8 штук (б/у с небольшим пробегом) +3 штуки ( новые в запас ) выставил на продажу, 6 тыс за все. Кому надо, забирайте. С входными на всех моноблоках определился на данный момент это старые GE 12AT7WA 50-е годы военной приемки, Телефункены и Бримары пробовал. Муллардов старых не было, но GE очень хорошо встали. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 12BH7A Менять 6414 на 12ВН7А можно смело без переделок? Я так понял у вас уже был опыт замены? Хочу на своих моноблоках поменять оригинальные 6414 GE на 12ВН7А, тк они начали "шуршать". Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 Да, это полные аналоги, просто меняешь и все. Сильвания 12ВН7А очень хороший драйвер, но поставил RCA 12ВН7А еще чуть лучше! GE 12ВН7А пока не ставил, RCA в фаворе, пусть поиграет. Все лампы новые. На Снапперы тоже драйверы сегодня заменил 7044 на 5687 и те и другие GE, пока сильной разницы не уловил, может чуть в басах получше, поиграют несколько дней попробую вернуть 7044 и уловить разницу. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 Я прикупил в драйвер японские National (Matsushita) 70-х годов. Сегодня поставлю. Надеюсь ничего не взорвётся. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Мефодий Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 6414 и 12BH7 по характеристикам абсолютно разные лампы. В очень редких случаях замена возможна, но при условии указания такой замены в мануале аппарата. Зависит от схемы и выбора рабочей точки производителем. Однако при замене 6414 на 12ВН7 будет разница в "громкости", потому, как коэфф. усиления 12ВН7 раза в два меньше. Если производитель не указывает возможности такой замены, делать этого не стОит, потому как "не встанет". Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 У Georgiy "встала" без последствий. И даже отмечает положительный эффект от замены. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 Из мануала Махи SWAPPING TUBES: Three tube types that are electrically and plug-socket compatible with the 12AT7A dual triode include the 6021, 6679, and the ECC81. There is no exact replacement for the 6414 dual triode, although the 12BH7 or 12AT7 are pin-compatible substitues, so in a pinch you can jam one of those in to get you by for a few days. The 6414 is really the best choice here, for this circuit, trust us. Actually think long and hard before just trying to score some golden lovely tubes on ebay for $125 each. Are they really what they claim to be? (Paint can be scraped off or applied at will.) Are they really new? (Hard to tell sometimes.) Are they tested? Were they tested for optimum performance in a Manley MAHI? We didn't think so. By virtue of our experience, testing, and selection we do recommend you obtain replacement tubes from the factory. We will indeed be looking after the best interests of you and your MAHI in our tube selection travails. Автоперевод: Три вида труб, которые электрически и подключаемых разъем, совместимый с 12AT7A двойной триод включают 6021, 6679, и ECC81. Там нет точной заменой для двойной триод 6414, хотя 12BH7 или 12AT7 являются совместимы по выводам Substitues, поэтому в крайнем случае можно варенье один из тех, кто в вас, чтобы получить от в течение нескольких дней.6414 действительно лучший выбор здесь, для этой схемы, нам доверяют. На самом деле думаю, долго и трудно, прежде чем просто пытается забить несколько золотых прекрасный труб на Ebay за $ 125 каждый. Являются ли они на самом деле то, что они утверждают, что? (Краска может быть соскрести или применяться по желанию). Являются ли они действительно новое? (Трудно сказать, иногда.) Они проходят? Были они проверили для оптимальной работы в Мэнли Махи? Мы не думаю. В силу нашего опыта, тестирования и отбора мы рекомендуем вам получить запасные трубки с завода. Мы действительно будет заботиться интересах вас и вашего Махи в нашем выборе трубки мучений. Конечно для Manley лучше когда клиент покупает у них запчасти и лампочки, но указание производителя на взаимозаменяемость есть, можно ставить. Из собственного опыта "при замене 6414 на 12ВН7 будет разница в "громкости"- не заметил, с громкостью все ОК. 1 Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Мефодий Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 (изменено) Ещё раз внимательно прочитайте #62 и найдите хотя бы одно отличие в анодно-сеточных характеристиках этих ламп. Изменено 6 октября 2015 пользователем Мефодий Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
marconi Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 в "громкости" заметной разницы не будет, ибо усиление определяется общей оос. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 (изменено) Поставил новые лампочки в драйвер. Ничего не взорвалось Их вклад в формирование конечного звукового подчерка очевиден и даже более очевиден чем от входных 12АТ7. Субъективно играть стало потише. Но не критично. В целом, влияние вносимое новыми лампами, не понравилось. Серединка стала более выражена и появилась яркость, правда не раздражающая. В целом подача стала менее "ламповой", если так можно выразится. Это пока не выводы а наблюдения. Выводы делать ещё рано. Изменено 6 октября 2015 пользователем Z.A.G. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Мефодий Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 (изменено) заметной разницы не будет, ибо усиление определяется общей оос. Вы правы. OOC - волшебная "таблэтка" от многих болезней. Спасибо Гарольду Блеку. Как инженер-связист, он даже и не догадывался о применении его изобретения в аудио. Изменено 6 октября 2015 пользователем Мефодий Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 Мефодий тогда если можно Ваше мнение о замене драйверной лампы 7044 на 5687 с учетом их реальных характеристик? Спасибо. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 Поставил новые лампочки в драйвер. Ничего не взорвалось Их вклад в формирование конечного звукового подчерка очевиден и даже более очевиден чем от входных 12АТ7... Исходя из мануала Махи можно и 12АТ7 в драйвер поставить... Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
marconi Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 7044 мне не нравится, слишком яркое, "поверхностное" звучание. 5687- тембристое, глубокое. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Мефодий Опубликовано: 6 октября 2015 Поделиться Опубликовано: 6 октября 2015 (изменено) Мефодий тогда если можно Ваше мнение о замене драйверной лампы 7044 на 5687 с учетом их реальных характеристик? Спасибо. Реальные характеристики близки. По звуку не скажу, как то мимо этих ламп, хотя 5687 есть в коллекции. По замене 5687 почитайте на форумах владельцев Кондо (там, не у нас), про 7044 есть отзывы. Ребята щепетильные, информация более достоверная . П.С. 7044 на 5687 меняйте смело, желательно на старый ТунгСол. Изменено 6 октября 2015 пользователем Мефодий 1 Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 8 октября 2015 Поделиться Опубликовано: 8 октября 2015 Поставил на вход своим 50-м моноблокам винтажные лампочки Valvo 6201 производства Hamburg 62-го года с золочёнными ножками. Великолепная лампа с великолепной подачей. В сравнении с винтажным Mulard 12AT7 подача ещё более бархатная, саунд подаётся плотнее, и плавнее с бОльшей проработкой тонких нюансов на средних частотах. Советую!!! Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Georgiy Опубликовано: 8 октября 2015 Поделиться Опубликовано: 8 октября 2015 То же сегодня заменил драйвер RCA 12BH7A на GE 12BH7A эффект 100% как у Вас "подача ещё более бархатная, саунд подаётся плотнее, и плавнее с бОльшей проработкой тонких нюансов на средних частотах" (у меня 50-е моноблоки озвучивают СЧ\Вч полосу). Так же поставил коннекторы AR RUR-1 на кабель, отлично играет, доволен! Теперь и входная и драйвер это лампы GE. Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Z.A.G. Опубликовано: 8 октября 2015 Поделиться Опубликовано: 8 октября 2015 Надо будет тоже попробовать что то из винтажного GE. Забавно, у меня крутилка глубины оос по другому градуированна, слева-min, справа-max На чем у вас установлены моноблоки? Цитата Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
