Топовые интегральные усилители - Страница 17 - Усилители - SoundEX - Клуб любителей хорошего звука Перейти к публикации
Равшанбек
New Vitus Audio SIA-030 Pure Class A Integrated Amplifier.        The all new Vitus SIA-030 is a step up from the highly regarded SIA-025 MKII integrated amplifier. Here is the preliminary info...        • 2.2KVA custom design transformer, vibration suspended.
• Approx. 400.000uF precapacitor bank
• Shielded preamplifier internal “chassis”
• Airflow optimized for maximum cooling with no fans.
• Extra transformer for all logic/CPU ect.
• Secondary capacitor bank of approx. 216.000uF
• Fully regulated PSU, also for output stage – similar to what is found in our MP-M201 4 chassis mono amplifiers.
• Key regulation technology insulated in add-on modules for easy upgradability, and extra shielding.
• Everything separated nicely, and in complete mirror configuration
• Standard inputs: 2x RCA unbalanced and 3x XLR fully balanced line inputs.
• Speaker Outputs are true balanced.
• Pre-out un-balanced to be compatible with most active subs.
• RJ45/USB logical inputs for easy firmware upgrades.
• Optional Phono stage and DAC/Streamer.
• Separate input selection board. Placed directly @ input connectors.
• Main preamp board paced at shield plate, which offers good shielding from especially power transformer.
• As usual using our modular design, for easy future upgrades.
• Placed on the back of the preamplifier board.
• New design taken from the MP-L201.
• Offers 0.5dB steps on every step.
• Signal path approx. 20mm though complete volume.
• Zero influence on bandwidth.        • 30W kl.A in 8ohm RMS
• 200W high biased kl. AB in 8 ohm RMS.
• Powerrating almost doubles for 4 ohm
• Kl. A / AB mode switchable
• Fully regulated PSU including output stage
• Linestage gain upto 12-18dB
• Phonostage supports MC/MM with max gain upto 70dB (expected)
  • 4 недели спустя...
Просто монстр какой то :Cool:        leonidas_Front20s.jpg
Leonidas Integrated Amplifier – Divine Line
Leonidas is a True integrated amplifier, able to uncompromisingly drive almost any load, promote the speaker’s true nature and characteristics without having to envy anything from it’s bigger brothers.Most integrateds are usually a compromising solution, for people who have less space or they like to have just one unit as an amp but his is not the case with Leonidas! A dual mono preamplifier and power amplifier with the definition of short signal paths in an one box amplifier solution with Pilium drive and sound! No compromises, no boundaries no limits!
Power:  200W/8Ω, 400W/4Ω, 800W/2Ω        Net Weight: 98kg !!!
  • 2 недели спустя...
Компания Audionet воспряла - представлен новый интегральный усилитель Humboldt: весящий 61 кг. он совладает с любыми колонками.
Audionet Humboldt вполне может носить титул суперинтегральник - судите сами: конструкция "двойное моно", дизайн Floating Pane, полностью устраняющий микрофонный эффект, использование нержавеющей стали для критических элементов корпуса, полная гальваническая развязка всех разъемов, покрытые родием коннекторы, четыре разделенных блока питания! Общая емкость конденсаторов у Audionet Humboldt - 400 000 μF, выходная мощность 2 х 250 Вт на 8 Ом или 2 х 380 Вт на 4 Ома, АЧХ от 0 до 700 000 Гц, "сигнал - шум" - 120 дБ, разделение каналов - 140 дБ.                                                  d859fd0f1d3392c0a4408bc238e224d8.png
У меня сейас один моноблок весит 60 кГ. И работа ещё не закончена. Для "крутости" пожалуй добавлю ещё килограмм по 10. Ну и 1000 Вт на 2 Ома. Это для так, на всяки случай.:LOL:
2 часа назад, Technician сказал:
Вам срочно надо познакомится с творцом цапа и домов из бруса :D
гигантомания величия...
Серия МАСТЕР это наверное тоже топ)
8 часов назад, anvar сказал:
сам себя не похвалишь :Kikik:,  сравнивал бы он свои моноблоки с Dan D'Agostino там по 258 кг каждый :LOL:
Да.... С юмором в Израиле явные проблемы...:Sure:
9 минут назад, Technician сказал:
у нас сейчас не до юмора, война.  С начала новой эскалации на юге по Израилю были выпущены 430 ракет.
22 часа назад, Равшанбек сказал:
Вот это монстр,Равшан где ты их раскапываешь? Интересно сколько будет стоить?
9 часов назад, הר זהב сказал:
Для себя родного стараюсь:)
Dan D'Agostino Progression Integrated - вÑÑÑеÑаем инÑегÑалÑник!        Dan D'Agostino Progression Integrated - встречаем интегральник!
Наконец, это случилось! Dan D'Agostino представит свой интегральный усилитель Progression Integrated!
Оформленный в виде полного решения, Dan D'Agostino Progression Integrated щеголяет традиционными медными радиаторами по бокам корпуса и "иллюминатором" на передней панели - спутать дизайн маэстро ни с чем нельзя. Все детали о новом Dan D'Agostino Progression Integrated станут известны уже 9 мая 2019 г. - премьера пройдет в рамках ближайшей выставке в Мюнхене.
Я чего-то не пронял, у него же  есть интегральник MOMENTUM https://dandagostino.com/products/momentum-integrated.php
Кстати, тот, что на картинке, здорово на него смахивает, хотя относится к серии с совершенно другим дизайном .
PROGRESSION ниже ступенькой в модельном ряду и, как принято было у KRELL, как мне кажется, будет без внешнего БП.
Нижняя часть явно меньшего размера.
1 час назад, E320 Sportline сказал:
Скоро узнаем :Cool:
В 04.05.2019 в 23:06, Technician сказал:
не весом определяется качество усилителя!
4 минуты назад, Леха Д сказал:
А весом трансформатора.
Не может быть!:Sure:
3 часа назад, Technician сказал:
и звучание  унча тем более!
4 часа назад, Roward сказал:
с трансформаторами не всё так просто!Вес транса может быть огромный а звук он может убить на прочь!
Вы просто не в теме. Хороший усилитель не может быть дешёвым. Так? А дорогой не может быть лёгким. Так? Отсюда следует, что хороший усилитель должен быть тяжёлым.
Простая логика.:Smile:
Да все оказалось совсем по другому        Dan D'Agostino Progression Integrated - официальный анонс!        Dan D'Agostino Progression Integrated - оÑиÑиалÑнÑй анонÑ!
Давно ожидаемый новейший интегральный усилитель Dan D'Agostino Progression Integrated представлен официально! Аппарат построен на модульной платформе, допускающей будущие апгрейды.
Dan D'Agostino Progression Integrated оснащается 3 XLR и 2 RCA входами, одним сквозным XLR каналом для домашнего кинотеатра, а также парой балансных выходов. Опционально можно разместить и встроенный фонокорректор для МС-головок. Комплектный пульт ДУ работает по Bluetooth. Вторая интересная опция - возможность добавить "на борт" цифро-аналоговый преобразователь экстра-класса (и, соответственно, пару SPDIF-входов, пару оптических входов, интерфейсы USB-A, USB-B, а также вшитые стриминговые клиенты Tidal, Qobuz) с параметрами приема сигналов до PCM 24/192, DSD 11,2 МГц.
Dan D'Agostino Progression Integrated развивает мощность в 2 х 200 Вт на нагрузку в 8 Ом или 2 х 400 Вт на 4 Ома. Отгрузки начнутся в августе 2019 г. - базовая версия будет стоить $18 000, за $20 000 предложат модель со встроенным фонокорректором, наконец, версия и с фонокорректором и с ЦАП'ом обойдется в $25 000.        Dan D        Dan D
В 05.05.2019 в 09:06, Gleb1969 сказал:
Если сзади списка считать)
В 11.05.2019 в 17:20, Равшанбек сказал:
Выглядит стрёмно ;(
  • Нравится 1
  • Смешно :) 1
  • Хммм 1
