Хорошие тесты в аудиожурналах которые запомнились - Страница 4 - Мир аудио - SoundEX - Клуб любителей хорошего звука Перейти к публикации
iu-ra
Кстати, вот пример упоминания в "Stereophile"  "косяков" оборудования, предоставленного на обзор :
"... I did experience problems with my first sample of the No.37. It occasionally failed to unmute when I engaged Play (all digital players mute the sound briefly until the player is up to speed and the digital data are stabilized). The track timer would begin counting, indicating operation, but there was no sound. Stopping and starting the player invariably got things working properly. The drawer also did not always close all the way (1/8" or so would stick out). A second sample functioned normally, but with a slightly noisy drawer action (a "twang," like the sound of a tweaked spring, could be heard on opening and closing) ..."
  • Ответы 89
8 минут назад, ДимON сказал:
У нас в АМ примерно так же глючил 390. Это ж середина нулевых была, когда они производство на лексикон перенесли, из Мидлтауна в Бедфорд, а там с качеством было полное биде...
А вот вам пример критики конструкции оборудования в обзоре в "Stereophile" :
"... However, other aspects of the Defy's construction leave something to be desired. For example, the heater supplies are regulated by a heatsinked TO-3can device mounted in a relatively unventilated part of the unit beneath the mains transformer. As a result of this regulator's position and of its own heat, this transformer runs hot. Its can becomes almost too hot to touch in warm weather. And several large electrolytic capacitors, including the massive 1000µF 500V output stage reservoirs, are bondedyes, glued!with RTV silicone to the underside of the chassis. While it is unlikely that they would fall off, this and some other points indicate an amateurish approach to certain aspects of construction, surprising considering the number of years Jadis has been in the business. ..."
В 03.06.2021 в 12:24, kkk2015 сказал:
про эти случаи потом легенды ходят
Отлично всё раскрывается парой сварочников в би-ампинге. Понятно, что к ресиверу Denon их не стоит подключать ..
В 02.06.2021 в 19:55, Игвин сказал:
Как ни странно - оба правы.
Сложный ЦАП, не у всех получается хорошее изделие на нём.
Если не уметь читать по английски или не иметь даташита, то наверное сложный.
18 часов назад, アントン сказал:
Антон, не гони понты. В их убогом даташите полно ошибок. Это говорят люди, у которых английский - родной язык. К тому же фирма заставляет подписывать NDA. Что само по себе нонсенс и бред.
Но это не главное.
Сложностей там и на физическом уровне хватает. И звук в результате далеко не у всех получается. Ты этот факт зачем пытаешься оспорить?
9 часов назад, Игвин сказал:
Но это не главное.
Он ни у кого не получается. А кто-то думает, что из-за обвязки или ещё чего. А оно просто врождённое.
Любой АКМ сразу лучше. Без усилий.
1 час назад, アントン сказал:
У моего приятеля есть ДАК на Сабре. Относительно неплохо работает, но да - отказался от него в пользу двух других.
Первый из них действительно на АКМ, второй на 1853. Между ними никак не выберет, оба нравятся.
https://www.accuphase.com/model/dc-950.html - норм ЦАП, кстати, ухи не режет... ;)
Любая тема начинается с обозначенной в заголовке и заканчивается  Бивнями.
И "все" их слышали и "всем" они не нравятся ( это пишу только люди, как будь то, эти Бивни им на голову упали и они им мстят).
И при этом, это самая покупаемая акустика в мире.
Парадокс.
10 часов назад, SFisher сказал:
Так поэтому "всем" и не нравится..
9 часов назад, SFisher сказал:
Парадокс.
Где можно посмотреть правдивую статистику по этой теме?
  • 1 год спустя...
Тоже почитывал ранее подобные журналы, и наши и забугорные (когда их тут и близко небыло).
Да, любое чтиво что то откладывает в голове. Любая  тематическая информация полезна, только стоит всё делить на восемь.
Аппаратуру покупал не по мурзилкам.
Почитал журналы, почитал форумы (тот тоже нужно делить уже на десять), сам послушал, посмотрел, пощупал.
Главное не торопится.
Но всё равно,  "перебор"  аудиожелеза не прошел мимо меня и забрал с собой кучу бабла, времени и нервов.
А почему всё это писательство - продукт субъективный.
Оценивают аудеожелезо  тоже субъективными понятиями.
И возвращаемся снова с чего начинали - в нашем хобби нет точных  параметров оценки качества.
Бросил читать аудиожурналы, и раздарил их приятелям после какой то очередной мурзилки Елбаева. Он там заявил что любые кабели надо менять хотя бы раз в несколько лет, так как они сильно изнашиваются и перестают отвечать заявленным характеристикам.
  • Perun изменил заголовок на Хорошие тесты в аудиожурналах которые запомнились
Елбаев - это же наипервейший журнальный, бумажный тролль...:D Как можно было всерьёз воспринимать ту пургу, что извергалась им?
