Топовые интегральные усилители - Page 51 - Усилители - SoundEX - Клуб любителей хорошего звука Jump to content
0450F394-688D-4FFF-9B44-4AA716B328D3.jpeg        E4AEAE46-4157-41FD-AAD4-55E26A862B36.jpeg        Great shots of the Silbatone JI 109 Hybrid Integrated Amplifier. Designed from the ground up to deliver timeless sonic per performance. Via Silbatone Acoustics Europe.
  • 2 weeks later...
010717-Inorecable-600.jpg        TIA240R Tube Integrated        TIA Series rear panel
TECHNICAL SPECIFICATIONS ------ TIA-280R
Power Output
Minimum sine wave continuous average power output per
channel, both channels operating is:
80 watts into a 4 ohm load or an 8 ohm load (ULTRA LINEAR mode)
40 watts into a 4 ohm load or an 8 ohm load (TRIODE mode)
Total Harmonic Distortion
Maximum Total Harmonic Distortion at any power level from 250 mill watts to rated power output is:
0.5% for a 4 or 8 ohm load
Frequency Response
+0, -3.0dB from 10Hz to 65,000Hz
+0, -0.5dB from 20Hz to 20,000Hz
Sensitivity
High Level: 450mV for 2.5V rated output
Power Amplifier Input: 2.5V for rated output
A-Weighted Signal To Noise Ratio
High Level: 99dB below rated output
Power Amplifier: 120dB below rated output
Inter-Modulation Distortion
Maximum Inter Modulation Distortion if instantaneous peak output does not exceed twice the rated output,
for any combination of frequencies from 20Hz to 20,000Hz is:
Input Impedance
High: Level, 100K ohms
Maximum Input Signal High Level: 8V
Voltage Gain
High Level to Main: 18dB
Wide Band Damping Factor
Greater than 50
Rated Power Band
20Hz to 20,000Hz
Power Requirements
100 Volts, 50/60Hz at 5.0 amps
110 Volts, 50/60Hz at 5.0 amps
120 Volts, 50/60Hz at 5.0 amps
220 Volts, 50/60Hz at 3.0 amps
230 Volts, 50/60Hz at 3.0 amps
240 Volts, 50/60Hz at 3.0 amps
Note: Refer to the rear panel of TIA-280R for the correct voltage.
Preamplifier Tube Compliment
2 -6SL7   Preamp Circuitry
2 -6SN7   High Level Circuitry
Power Amplifier Tube Compliment
4 - KT120
Power Regulation (Preamp Section)
2 - GZ34
Overall Dimensions
Width is 16-7/8 inches (43.0cm)
Height is 9-1/8 inches (23.0cm) including feet
Depth is 16-7/8 inches (43.0cm) including the Front Panel and Knobs
Weight
76 pounds (34.5kg) net, 81 pounds (36.5kg) in shipping carton
Image        Image        AUDIO HUNGARY QUALITON X200 INTEGRATED AMPLIFIER        Audio Hungary Qualiton X200 - это интегрированный сбалансированный ламповый стереоусилитель мощностью 100 Вт на канал. X200 оснащен входными лампами 12AX7 и 6922 динамическими лампами. Выходной каскад основан на серии силовых тетродов KT, а X200 совместим с KT88, KT90, KT120, KT150 и KT170. Qualiton X200 имеет полностью симметричную конструкцию выходного трансформатора и плавающее выходное соединение. Выходной шум дополнительно снижен за счет полностью сбалансированной конструкции. Выходная мощность до 180 Вт на 4 Ом доступна при использовании силовых ламп KT170. PRICE 4990€
В 10.01.2021 в 14:02, fadler сказал:
импульсники дороже.
По себестоимости дешевле.
Jeff Rowland и Solution давно применяют ИБП в своих усилителях.
Отзывы, в абсолютном большинстве, только положительные.
Я просто сейчас выбираю себе новый мощник и JR один из кандидатов, так что тема ИБП мне интересна.
А Равшан, я смотрю, полностью переключился на лампу)))
Только что, Relax сказал:
И в Т+А, тоже вроде ИБП встречаются!
Все правильно, они уменьшают себестоимость именно питающей части, плюс вес, соответственно все это можно вложить в непосредственно в сам блок усиления.
52 минуты назад, Relax сказал:
Вообще-то ровно наоборот.
5 минут назад, アントン сказал:
Про JF  точно нет, Солюшен не сильно интересовал из-за цены.
Я уже несколько дней сеть мониторю, как-то не хочется выкидывать     ...надцать тысяч баксов просто так))))
Можно ссылку на отрицательные про JF, буду признателен.
23 минуты назад, fadler сказал:
вы сравнивали импульсный блок питания солюшена с их старыми трансформаторами? вы инженер, вам и работать
Единственная причина существования импульсных БП - габариты и дешевизна.
Их импеданс делает их малопригодными для мощных усилителей. Да и помехи глуши не глуши останутся.
24 минуты назад, Relax сказал:
Тут есть бывшие владельцы.
28 минут назад, アントン сказал:
но чуваки (https://www.spemot.com/products.html) решили рискнуть
35 минут назад, アントン сказал:
Что-то молчат..может напишите(можно в лику) кто конкретно, я спрошу в частном порядке, для меня это важно.
 Насчет Ямахи не скажу , но у меня был Jeff Rowland за 20 куе , который в классе Д , но с хорошим, линейным БП и он оказался хуже и заметно  авторского ум в классе АБ ,
Понятно )))
Только таких усилителей у JF сейчас нет, может и были когда.
Вы случаем D класс с ИБП не попутали? )))
псы: этот предназначается не Алексею)))
Что то ажиотажа среди аудиофилов уже не видно...
Если интересуетесь классом D, то вроде один из лучших брендов - Merrill Audio. На этом канале было сравнение с Грифоном и Дагостино.
6 минут назад, Азиз сказал:
JR и Солюшен не D класс, обычный АВ, у них просто импульсный блок питания. Чистый D мне не интересен. Были бы деньги, взял бы nad m32\m33  во вторую систему и не более, 5000 баксов за него отдать можно, но не больше, играют, кстати, очень прилично.
5 часов назад, Relax сказал:
А можно узнать , где есть информация ,что  JR работает в классическом классе АБ ? А то , все что я знаю и по своим древним но , не актуальным уже моделям , и по современным , например 535 , ничего даже близко не намекает на АБ ? :)
Зы.Сори , посыпаю голову пеплом , нашел инфо прям на сайте и нашел фотки 725 .Но если честно , все это выглядит очень странно для такой мощности . В любом случае надо рассеивать тепло от 650 вт/4Ом , а размер корпуса совсем не про такие мощности . Ну и ладушки . Удачи вам с этим усилителем .
Забавный кстати обзор по 535, почитайте ,может пригодится.
Jeff Rowland 535 Stereo Amplifier Review | Audio Science Review (ASR) Forum
Жаль что у Odysseus нет XLR входов, по цене он более реальный :Cool:        ody_back.jpg
  • 4 weeks later...
Всего 300 интегральных усилителей L-595A SE выпустит Luxman к своему 95-летию.        Интегральный усилитель Luxman L-595A SE        Интегральный усилитель Luxman L-595A SE        Интегральный усилитель Luxman L-595A SE        Юбилейная версия интегрального усилителя Luxman L-595A SE будет выпущена в количестве 300 экземпляров, причем каждый аппарат будет отмечен специальной табличкой с уникальным номером. В Великобритании усилитель можно приобрести за 11 тысяч фунтов стерлингов.        Номинальная мощность: 30 Вт (8 Ом), 60 Вт (4 Ом) в чистом классе А.
В 12.04.2021 в 01:40, Равшанбек сказал:
Integrated Amplifier, in Class A or Class AB
Hybrid, Zero Feedback, in Class A or Class AB.
The amplifier is designed to drive any kind of loudspeakers systems.
The LEVANTE integrated amplifier has all the elements that distinguish the Riviera amplifiers (Hybrid Circuit and Zero Feedback). It has also an extra feature that makes it unique: the option to choose between pure Class A and Class AB operation. A switch on the front panel allows to select the operating class according to your preferences or needs.
In Class A mode it offers 2x30W into 8 ohms (2x60W into 4 ohms); in Class AB it offers 2x120W into 8 ohms (2x200W into 4 ohms). Note that, even in AB Class, the first 6 Watts are in Class A.
  • Class A / Class AB switch
  • Pure Class A power 2x30W into 8 ohms
  • Class AB power 2x120W into 8 ohm (2x200W into 4 ohm)
  • Zero Feedback
  • Hybrid circuit
  • 1 balanced line input (XLR)
  • 4 unbalanced line inputs (RCA)
  • Speaker and headphone outputs
  • Optional phono card
  • Remote control
Dimensions: 44x49x19.5h cm. Weight: 30 Kg.
levante2sm.jpg        Riviera Audio Laboratories Levante Integrated Amplifier
Price: $16,500
В 11.06.2021 в 14:36, Равшанбек сказал:
Как же любят,все эти компании "баблеца рубануть." на любые свои круглые и не очень круглые даты! На столетие надо ждать усилок за 22000£.:Kikik:
  • Perun locked and unlocked this topic
